TSB - Technical Bulletins
 Nissan Titan Forums : Problems / Technical : TSB - Technical Bulletins
Subject Topic: Tire Low Pressure Light Post ReplyPost New Topic
BMWTitanMan
Posted: Jan 09 2005 at 10:20pm | IP Logged Quote BMWTitanMan
you wont say that at 85 miles pert hour and you pick up a nail on the highway and your truck doesnt flip--trust me its worth it thats why you insurance is so low on a 305hp truck
Back to Top View BMWTitanMan's Profile Search for other posts by BMWTitanMan
RedRocket
Posted: Jan 19 2005 at 7:53pm | IP Logged Quote RedRocket
We just emerged from a couple of weeks of below zero temps. The tire pressure lights were on the entire time. They went off after the temp return to the 20-30 rangs. The SERVICE ENGINE lite was also on during the lowest of temps, and then also shut off in the 20's and 30's.
The tailgate would not close when it got in the -20's. Quite exciting (ow) when you open the ARE fiberglass cover and the gate nails you in the chest.
Truck was pretty stiff when mega cold, but Mobil 1 keeps the motor ticking!
Back to Top View RedRocket's Profile Search for other posts by RedRocket
Gwhizz
Posted: Jan 22 2005 at 2:31pm | IP Logged Quote Gwhizz
I have had problems with the warning light not going out.  The dealer replaced it once, saying it was defective.  Now the temp dropped and it came back on again!  Tire pressures are fine.  Will have dealer check again when I bring it in for service!
GTW - Las Vegas - Titan Crew Cab 4x4 Le Off Road, Tow Package - 6 " Lift, Air Intake, Pro comp 17" x 35 all terrain
Back to Top View Gwhizz's Profile Search for other posts by Gwhizz
bobh55
Posted: Mar 16 2005 at 1:11pm | IP Logged Quote bobh55
My 2004 Titan does the same thing, it gets below 25 and the light comes on, when it warms up to around 50 it goes off. The dealer said there was problems with the sensors and they would have to be replaced, every time i want to take it back, the light goes out, they said the light has to be on for the warranty????????
Back to Top View bobh55's Profile Search for other posts by bobh55
Loumorelli
U.S. - Pennsylvania
Posted: Mar 16 2005 at 2:18pm | IP Logged Quote Loumorelli
bobh55 - Check your tire pressure gage and make sure it is accurate.  I was having the same problem, but found my tire gage was inaccurate.  See my post on page one of this forum.  Also repeated below.
Problem solved.  My tire pressure gage was not accurate.  If you have a pressure gage that has a rod that protrudes out the bottom and shows a linear scale of pressure make sure you hold it so the rod points upwards.  Gravity was effecting my gage and it indicated a higher pressure than was actually in the tire.  Once I re-adjusted my tires to about 36 psi and drove a mile or two the low pressure light went out.
I have not had any problems since.  We have had some very cold days since that time (January 6th 2005) here in eastern PA.
2004 Nissan Titan SE Crew Cab, 4WD, Off Road Pkg, Tow Pkg, Utility Bed Pkg, Rockford Fosgate Sterio, Air Bags
Back to Top View Loumorelli's Profile Search for other posts by Loumorelli
noel55
Posted: Jul 26 2005 at 7:53am | IP Logged Quote noel55
my tire pressure gauges where removed becuase they all broke due to a fusing of an after market cap to the stem but that is besides the point.  before this happened I noticed the light come on when gping around a corner kinda hard well i couldn't check the pressure cuase of the afore mentioned problem but when I had new tires put on teh pressure guages where removed and funny thing is the light still comes on around turns.  hmmmmmm so is it even working in the first place.  Mine did go off once on a very cold morningwell below freezing but they had dropped to 26 lbs so i filled to 35 and no problems since.  Makes you wonder with all the brake problems with these trucks if they screwed something up on mine taking the damn tires on and off the more than 7 times in 1 and a half years i had it.
Back to Top View noel55's Profile Search for other posts by noel55
04titancc
U.S. - Mississippi
Posted: Jul 30 2005 at 12:15am | IP Logged Quote 04titancc
I have aftermarket wheels on mine and didn't put the sensors in the new wheels.   After a ~35-40 miles, my light will come on.  This is crazy b/c the sensors are passive until the psi drops then they send out a signal to trigger the light.  If the factory wheels 35 miles away...why does the freeking light keep comeing on???
I think it is a glitch!!!
Flowmaster 40 single in dual out w/turn downs
Back to Top View 04titancc's Profile Search for other posts by 04titancc
Hosehead
U.S. - Pennsylvania
Posted: Oct 25 2005 at 3:33pm | IP Logged Quote Hosehead
Has to be...my tire pressures are all fine, and the light stays on.  The alarm also kicks in occasionally, just to keep me alert.....
Lieutenant 2-13
FTM-PTB-EGH
"Ní bheidh mo leithéid arís ann!"
2004 King Cab LE- Canteen
Back to Top View Hosehead's Profile Search for other posts by Hosehead Visit Hosehead's Homepage
Pax River Titan
U.S. - Maryland
Posted: Dec 04 2005 at 7:38pm | IP Logged Quote Pax River Titan
I've had this problem on my 04 when the temperature drops below freezing. Last time had the dealer ck it. He says the tires were low by 4 lbs. Seems to have worked. I'm going to get a new dial gauge and keep an eye on it. Nissan, if you're listening, make this feature optional.
dap
Back to Top View Pax River Titan's Profile Search for other posts by Pax River Titan
pied_piper
Posted: Dec 04 2005 at 7:48pm | IP Logged Quote pied_piper
I have made a post earlier about this thing. I was having constant tire pressure loss on 3 tires, and when they were checked, it looks as though as the seal around the sensor was giving way. They tire guy said that he thought the sensor itself was too big, causing the problem.
<< Prev Page of 3 Next >>
