jjarocki Newbie
Posted: Feb 14 2005 at 4:56pm | IP Logged
Just wanted to let you know, and this may have been posted, that Sirius can be installed in the Titan. I had mine put in at Grubbs Nissan in Bedford Texas and it works great through the factory radio.
One nice feature, they used an antenna that is mounted on the inside of the front windshield near the mirror. Reception was very good on a recent trip from Dallas to Atlanta and it looks very nice.
Hosehead Newbie
Posted: Feb 19 2005 at 9:13am | IP Logged
What year is your truck? The burning question is whether
the Sirius can be installed with the factory radio in the 04. It
is definitely available in the 2005.
KL
__________________ Lieutenant 2-13
FTM-PTB-EGH
"Ní bheidh mo leithéid arís ann!"
2004 King Cab LE- Canteen
sonnytimes Senior Member
Posted: Feb 20 2005 at 6:35pm | IP Logged
Can you post any pictures
BLKTITANLE Newbie
Posted: Feb 20 2005 at 9:56pm | IP Logged
Factory Sirus or Factory XM can be installed in the 04. The only issue is that the early 04 requires the replacement of mounting brackets inside the dash (for SIRUS or XM).
__________________ 2004 NISSAN TITAN LE 4x4: KING CAB; BLACK; OFF-ROAD; FACTORY XM
norse39 Groupie
Online Status: Offline Posts: 42
Posted: Feb 22 2005 at 6:55am | IP Logged
I went with Sirius because I had XM in my chevy and never listened to it. The format didn't grab me. I heard Sirius and was hooked! Nissan finally has the option listed on their web site but when I got my Titan, I had to ask for it because they didn't advertise it at the dealership.
__________________ Forney,TX
2005 LE CC 4X2 Smoke W/Mats, BigTow, CustomGrill, Sirius,A.R.E. Tonneau Cover, Eurolite HID Xenon, Debadged
Hosehead Newbie
Posted: Feb 25 2005 at 12:04pm | IP Logged
of mounting brackets inside the dash (for SIRUS or XM). |
Then why does Nissan and the dealer keep telling me otherwise? They insist that only the XM is available for the 2004...
FTM-PTB-EGH
BLKTITANLE Newbie
Posted: Feb 25 2005 at 2:22pm | IP Logged
The Nissan Guy probably doesn't know what he is talking about. XM was first released and marketed for the NISSAN digital upgrade. Therefore all the liteature is from XM. However, the XM and SIRUS connect the same way and are the same size. Though an N-BUS connect which is in the dash under the steering wheel. I brought my XM off EBay second-hand from a guy who replaced it with SIRUS becuase he wanted to listen to NFL games. There is some retailer that sell the tuner for around $175.00 on Ebay, diffently cheaper than the $400.00 from the dealer. If you have an earlier model, it will require the mounting brackets replaced, the brackets cost about $20.00 but it is a pain. I factory antennea work great, and you can find them for $50.00 - $75.00, expense but nice. It installed on the rear window in the driver-upper side .... out of view from the rear mirror and side mirror and low enough to fit in a garage.
Hosehead Newbie
Posted: Mar 01 2005 at 5:50pm | IP Logged
If
there is anyone who has had a dealer install a Sirius factory radio in
a 2004, please pass along your delaer contact info. That way I
can get my dealer to call your dealer (sounds like 'Let's Make a Drug
Deal').
Thanks in advance,
KL
FTM-PTB-EGH
WanPintu Newbie
Posted: Mar 04 2005 at 10:15am | IP Logged
Has anyone seen how this looks with the factory radio? Meaning do
you still only get 1 line of display? Do the song titles scroll?
and do you only get 6 presets or does the sat have 2 like FM1/FM2?
I purchased a SIRIUS sportster about 2 months ago, but have not got
around to installing it yet. I would much rather have a cleaner
install and use the factory radio at the same time.
Wan
2004 Titan SE 4x4, Factory Running Borads
norse39 Groupie
Posted: Mar 04 2005 at 10:31am | IP Logged
WanPintu wrote:
Has anyone seen how this looks with the factory radio? Meaning do you still only get 1 line of display? Do the song titles scroll? and do you only get 6 presets or does the sat have 2 like FM1/FM2?
I purchased a SIRIUS sportster about 2 months ago, but have not got around to installing it yet. I would much rather have a cleaner install and use the factory radio at the same time.
Wan ---------------------------------- 2004 Titan SE 4x4, Factory Running Borads
The Sirius Factory install has only one line of display. But by pressing the right hand knob you can select Artist or title. If the label is too long for the display, use the right knob to scroll to see the rest of the display. You can also designate if you want the main display to show channel name, channel number,artist name or song title. As far as the program buttons go, There is A-B-C. I have A setup for local stations and I setup B & C for Sirius stations.
The only thing I didn't like is that you access sirius by pressing the radio btn, scrolling thru AM, FM and SAT. I wish there was a SAT btn like they had for XM. That way you could have an A-B-C for SAT only. Other than that little gripe, I love it! No low volume like you would have thru the input jack. The sirius seems to have a little more bass to it than the radio or CD. The SAT antenna is mounted inside the vehicle just in front of the rearview mirror. Nice and clean and not blocking your view!
