Subject Topic: XM Radio Post ReplyPost New Topic
BuyDell
Posted: Dec 31 2004 at 3:59pm | IP Logged Quote BuyDell
Any of you guys have a problem pulling down the headliner in the inside rear of the TITAN ?? I see there are 2 "buttons" to pull out but after that I was afriad that I might put a kink in the headliner pulling it down to get to the 3rd brake light !!!!!
04 LE CC, 4x4, Pearl White, Big Tow Package
18in Wheels
Back to Top View BuyDell's Profile Search for other posts by BuyDell
savannahtitan
Posted: Jan 21 2005 at 8:05pm | IP Logged Quote savannahtitan
I have a silver Titan and had the dealer install the Sirius option.  They subbed it out to a local audio install shop and I talked to them after they did it.  I have the navigation/fosgate system.  The Sirius Kit came in 3 pieces.  One is a (1) larger bracket that mounts on the brake pedal assembly that accepts what is currently there on a smaller bracket and the (2) Sirius box.  Next is the (3) antenna install.  Unlike the XM, the Sirius actually installs inside the cab, just to the right of the rear view mirror and works THROUGH the glass.  It is V shaped (Triangular) and attaches to the glass.  If you have the dealer Sirius factory unit when you call to activate it Sirius gives you three (3) months free service which is cool.  The nice part about the system is that you can see the track/info through the bottom of the nav screen (although the text is one line, it should be 2 or 3 lines and smaller and scroll which it doesn't) and you can see additional info by pushing the right button in.  I have had XM and Sirius (both at the same time in different vehichles before I got the Titan) and I like Sirius WAY better than XM (imho/In my humble opinion).  Channel 21/22/23 are my favorites and I like the 60s for club/dj remixes and check out 145 also Sirius is going to be offering Digital (like DirecTV) Satellite service in less than 2 years and XM has no plans to do that yet.  I am going to add a real HID (High Intensity Discharge) unit to the truck next week, the kit is on the way from Japan.  It is an actual 4 HID Light kit (because the Titan has 4 bulbs.  Most kits only do low beams which is fine just use Silver Stars for the highs if you want it to match closer) so I will post on that when it is done, along with pics of before and after shots for the forums.  I would like to hear from anyone that has the tronneau aluminum covers, either roll up or one flat piece.
Back to Top View savannahtitan's Profile Search for other posts by savannahtitan
<< Prev Page of 7
