jkenn1212 Newbie
Posted: May 16 2005 at 12:36pm | IP Logged
HAS ANY ONE HAD ANY PROBLEMS WITH THE STOCK RADIO NOT READING BURNED CD'S...???
bigbear05 Moderator Group
Posted: May 17 2005 at 7:53am | IP Logged
If you are refering to the actual CD, I don't know of any. I have heard that the head unit will not read the disc title, track title and etc of a burnt cd unless you have a certain type of burning software. Hope this helped. May want to get you head unit checked out. Does it read store bought cd's?
Posted: May 17 2005 at 2:41pm | IP Logged
I've had no problem playing burnt CD's, but never really paid attention the the screen display showing the track, band, etc. I've only noticed it showing that info on store bought CD's.
jkenn1212 Newbie
Posted: May 18 2005 at 1:13pm | IP Logged
well my 6 disc will not read/play songs on the cd, you can hear the lens moving back and forth, like it is trying to find info, but can't. store purchased cd's play fine.
04 SE CC
DEEP WATER BLUE, BIG TOW
swigley Newbie
Posted: May 18 2005 at 9:44pm | IP Logged
I've got the Rockford Fosgate 6 CD chger and I don't have a problem with burned cd's this is what I use to burn:
Burning software: Ahead Nero ver 6.6 (I almost never get coasters with Nero)
select new "audio cd" (ensure that the audio compilation properties indicates to write cd text on CD) the RF system can read this.
Also you should ensure that on the write method you select "Disc at once" or "Disc at once/96"
If this alone doesn't work try burning at a slightly slower speed.
__________________ ~swigley
Posted: May 19 2005 at 12:27pm | IP Logged
I use roxio and we can't get the text....lokks like a change is in order or maybe reading the instruction PDF
=Viper= Newbie
Posted: May 25 2005 at 9:59pm | IP Logged
ive got the stock cd player in my 05' titan and most likly half my cds are burned and i have no problem.
shizod Groupie
Posted: May 31 2005 at 12:06pm | IP Logged
I have no problems as well, and I find that if you tag your music before you burn it then the player will read the text.
__________________ 05 KC SE 2WD
Rockford, Big Tow
smoke grey
volant intake
HID conversion 5000K
Mavryck Groupie
Posted: May 31 2005 at 9:38pm | IP Logged
I only use burned cds in my vehicles. I found that if I just copy a cd the track and cd titles don't show up on the display. However, if I create a cd from files on my hard drive the titles display fine. Only two of my store bought cds dislpay titles.
__________________ Mavryck
wolfin1 Newbie
Posted: Jun 06 2005 at 12:49pm | IP Logged
Does the RF 6CD changer read .mp3 format disks?
