jaysonstuart Newbie
Posted: Jun 19 2004 at 4:14am | IP Logged
Well my display is on the radio display, I don't have the navigation system installed so I'm not sure if it works with that. And to be honest I never listen to FM anymore since I've had the XM. But I have heard the FM recpeption on the TItan stereos isn't all that great.
syntrix Newbie
Posted: Jun 19 2004 at 4:35am | IP Logged
JoeyCrack wrote:
duckslayer30 wrote:
somewhat off the subject but the rockford foossgate system in the nissans is horrible it is just like the bose and infinity and all that other crap it is made by some company for rf or infinity if you look at the speakers they are the same as in my truck with regular radio the only difference is your has a sub |
thats not entirely correct. In numerous factory systems the difference is that the factory system when upgraded has an amp that powers the speakers rather then just using deck power. Take the monsoon system used in GM and VW for example. Some guys have had success in Sound Quality stereo competitions by keeping the factory midbass because it performed so well. In the end it all depends on your expectations and what you'd like under warranty, say for instance you install an aftermarket system and fry your electrical system which isn't too likely but anything is a possibility. |
I'm actually one person that has modified a monsoon twice in two new vw's.
great stock system!
However for the audiophile, you really should strip the stereo (funny how I had the keys already) and start from scratch.
However most people can't do that. If you tune the HU for midrange and even add in a high level converter for the subs, you can actually have a great system!
Most of the "factory sucks, or RF/infinity sucks are from true audiophiles. But if you compare factory to upgraded without the boom boom and 12thousand watts, you really have good consumer system.
Now upgrading to better levels is something outside of factory offerings!
noel55 Newbie
Online Status: Offline Posts: 37
Posted: May 24 2006 at 8:35pm | IP Logged
does anyone know if you can swap out the plain 6cd changer unit for the Rockford without doing anything special
earlofcrankcase Senior Member
Online Status: Offline Posts: 230
Posted: May 25 2006 at 12:49am | IP Logged
I know first hand the 6cd rockford fagsgate has bad FM reception so ... What's the point?
(key phrase) designed by! Just go to Walmart & by a panasonic they were willing to put their name on the front of.
Wake up.
noel55 Newbie
Posted: May 25 2006 at 7:17am | IP Logged
thats great but it doesn't answer my question of weather this is a clean upgrade or do i need the amp or new speakers etc...
miserytom Senior Member
Posted: Dec 12 2006 at 4:24pm | IP Logged
as for the original question on the thread,
3 on dash
1 on each front door
2 on each rear door
1 sub
10 speakers
Posted: Dec 13 2006 at 8:37am | IP Logged
also, KC has 8, CC has 10.
Warrior52784 Newbie
Posted: Mar 30 2007 at 3:41pm | IP Logged
I would have to agree. If you are coming from a vehicle with an after market audio sytem that was custom designed then no you are not going to have your expectations met. I have heard the rf system and it sounds really good for what it is for. You also have to understand that this is not going to be a "blow you a way" kind of sytem. Nissan has to make it marketable for most age groups. You can fine tune it and it will sound it will sound better as long as you know what you are doing. I have had all kinds of after market sytems in my vehicles and I have come to realize that it really is the quality of the sound rather than quantity. If you are trying to let everyone outside the truck hear what you are listening to then this is not for you, but if you want quality sound than this system is great for that.
__________________ Some times life can throw you a curve. You may swing and miss alot but when you finally connect and send one far over the center field wall, it was worth every one
