Posted: Mar 03 2006 at 12:29am | IP Logged
[QUOTE=pied_piper]I'll try to answer some of your questions best as I can.
Diesel-more power, usually better mpg, used to be cheaper than gas.
Front level kit-if you noticed, the Titan as a slant, with the
backend higher than the front. The initial purpose of this was supposed
to give the truck more clearance while backing up (a hill I guess). The
kit would raise the front end to match the height of the backend.
Kinda blank on the ARE lid.
This is the first time I've heard of the Front Level kit, not sure if
it would make that much difference to me if I had it or not. As
long as their is clearence to change my own oil (with Mobil 1) its
plenty high enough. How high is the front end usually raised to
match the back end? Haven't given it much thought. I'm
leaning toward either the Red Braun, the Smoke or the Blizzard
White. If they would ever come out with a Desiel I might
think about it, but since I would like an 06, I probably won't get a
Diesel. What color is your Titan and is it an 06, 05?
__________________ This is the message we have heard from Him and announce to you, that God is Light, and in Him there is no darkness at all.
