Titan Towing / Hauling
 Nissan Titan Forums : Titan Towing / Hauling
Subject Topic: Aftermarket tow Post ReplyPost New Topic
Titan05
Posted: Feb 02 2005 at 10:38am | IP Logged Quote Titan05
jfivejay5 wrote:
     For the most part, mine was just as easy.  Also bought from etrailer.com.  Since my Titan did not have the big tow package (hence, needed a hitch) the relays in the fuse box under the hood were also not there.  These relays supply the power to the pre-wired harness behind the bumper.  The dealer wanted $80 for the two relays.  I declined and found them elsewhere.  The hitch bolted on nice and easy and the the plug is just as simple, as long as you have the relays.  Hope this helps.
Titan05
Back to Top View Titan05's Profile Search for other posts by Titan05
'04 off road
Posted: Feb 09 2005 at 8:03pm | IP Logged Quote '04 off road
I paid $229 for a factory hitch and it took 15 min to install it also comes with the necessary relays for the wiring that need to be installed under the hood it is a heavy hitch and it says 10,000 pounds right on it of course ill never attempt that kind of weight lol
Back to Top View '04 off road's Profile Search for other posts by '04 off road
LinkNuc
U.S. - Pennsylvania
Posted: Mar 15 2005 at 11:39am | IP Logged Quote LinkNuc
Courtesy Nissan has the Class IV package for 211 bucks see if you can work a deal out on shipping and its worth it..
www.courtesyparts.com
2005 King Cab SE Smoke, RIP '03 Blown Brickyard Z
Back to Top View LinkNuc's Profile Search for other posts by LinkNuc
<< Prev Page of 3
