Subject Topic: How to Change Headlight Bulbs ? Post ReplyPost New Topic
goloso30
Posted: Nov 30 2004 at 7:06pm | IP Logged Quote goloso30
Does anyone know how to change the headlight bulbs ?? I took a look under the hood and seems damn near impossible. Its just a darn bulb ...
Back to Top View goloso30's Profile Search for other posts by goloso30
gr8TITAN
Posted: Dec 01 2004 at 2:48pm | IP Logged Quote gr8TITAN
Access the headlight assembly from the back through the front wheel well openings. There is one screw (phillips head)  that you need to remove, pull back the plastic wheelwell liner and reach for the base of the bulbs. They twist 1/4 turn and PRESTO!!! To re-install, reverse above steps. Ease of job rated from 1-10: This is a 2.
04 TITAN4x4CC
Back to Top View gr8TITAN's Profile Search for other posts by gr8TITAN Visit gr8TITAN's Homepage
Posted: Dec 01 2004 at 3:10pm | IP Logged Quote thepuffman
<<<Agrees with gr8TITAN..is a pretty easy task...one tip...dont handle the new bulbs with your bare hands..they claim oil from your hands will shorten the life of the bulb...I used latex gloves...added benefit of extra grip....GL
goloso30
Posted: Dec 02 2004 at 12:21am | IP Logged Quote goloso30
Thank you...Very much sounds easy enough ... Never thought of going through the wheel well for a bulb change
jdmm
U.S. - Louisiana
Posted: Dec 02 2004 at 5:35am | IP Logged Quote jdmm
When changing the driver side bulb turn the steering wheel all the way to the left.
Look near the bottom of the wheelwell (front of it) and there is a phillips head screw. Loosen it and pull back. You can look up in there and see both headlites.
Back to Top View jdmm's Profile Search for other posts by jdmm
