Subject Topic: Dealer BS Post ReplyPost New Topic
Onelowmini
Posted: Dec 04 2004 at 5:01am | IP Logged Quote Onelowmini
So I have had the normal rotor warp. Here is the story, First trip to the dealer they turned the rotors and ordered the updated brake kit. Second trip they installed new brake kit and turned the rotors again. Didnt solve the problem, So THIRD trip they installed new rotors and pads. Still shook like crazy. So FOURTH trip they insisted they put new rotors up front and told me to get my alignment, and balance and rotate tires, So I did it and it didnt fix the problem, Took it back for the FIFTH time and they said I had a bent axle and it was my fault so they would not warranty it. Ok screw them I took it to another dealer. This dealer said that my front rotors were under spec, which means the other dealer did not replace them, and so they replaced them along with turning my rear left rotor. It doesnt shake anymore but the dealer said that it will. Nissan is on there third brake kit and talking about replacing the whole brake package. So we will see. DONT GO TO RACEWAY NISSAN.
Back to Top View Onelowmini's Profile Search for other posts by Onelowmini
been there
Posted: Dec 07 2004 at 3:12pm | IP Logged Quote been there
This is my opion. If the rotors warp and then they get turned down even thinner, they will warp twice as fast,Rotors should never be turned..... I have around 700 mi on my 4x4 crew cab and hav'nt experinced any of the problems posted, only lousy gas mi, about 10, and i dont hot rod, thats why i traded in my 04 z.
been there
Back to Top View been there's Profile Search for other posts by been there
