Subject Topic: Rear differential oil Post ReplyPost New Topic
meekone
Posted: Dec 26 2004 at 6:27pm | IP Logged Quote meekone
I have a 2004  Titan  4x4 SE with the big tow pkg. I am going to change the front and rear differential oil with Mobil 1 synthetic gear lubricant. I have read that under severe conditions the stock oil will break down overheat and cause failure. Mobil 1 has two available a 75W140 and 75W90, The owners manual lists SAE 80 . Which one of the Mobil 1 products would be the best to use?
Back to Top View meekone's Profile Search for other posts by meekone
lowlypawn
Posted: Dec 31 2004 at 7:26pm | IP Logged Quote lowlypawn
I just bought some 75/90 Mobil 1 for my titan.
But I really don't think it makes a difference. Use what ever makes you feel better.
I have always preferred oils with the smallest viscosity range because it mean there are less of little threads (forgot what they are called, they change size depending on temperature) and more pure oil.
Back to Top View lowlypawn's Profile Search for other posts by lowlypawn
