Subject Topic: 12v Power in Bed Post ReplyPost New Topic
kastnblast
Posted: Dec 31 2004 at 12:32pm | IP Logged Quote kastnblast
I'd like to put a pair of 12v outlets into my truck bed to run a pair of those little ceramic heaters (150w ea., sold as windshield defrosters) to keep my bird dogs warm in their crates. Where and how can I easily pull power from?
Thanks!
Back to Top View kastnblast's Profile Search for other posts by kastnblast
Posted: Jan 03 2005 at 3:28pm | IP Logged Quote thepuffman
You mean they dont get to ride up front?........jk....Hmmm, not sure about that one, but with all the wind in the bed would it do any good?..or do you have a bedcap? If you have a rear sliding window, maybe you could find a 12v DC extension cord...surely someone makes one???
see below
http://www.ba-electronics.com/12v-acc.htm
kastnblast
Posted: Jan 03 2005 at 7:46pm | IP Logged Quote kastnblast
No room up front! ...The dog crates have covers on them, and the little heaters combined with the dog's own body heat should be all they need. If there is no convenient spot to tap the wiring harness for some +12 v, I'll probably just run a 14 ga. lead to the battery terminal with an in-line breaker.
Thanks.
Atomboy
U.S. - Washington
Posted: Jan 03 2005 at 7:57pm | IP Logged Quote Atomboy
Hi Kastnblast,
I have the 12 volt outlet in the utility bed package and it's located about a foot forward of the tail lamp assembly on the drivers side.  I would imagine they are coming off that left side tail lamp assembly.  That is also where they the hooked up the canopy wiring so look for a pigtail or unused plug.  Good luck keeping the dogs warm!
Back to Top View Atomboy's Profile Search for other posts by Atomboy
kastnblast
Posted: Jan 04 2005 at 9:43am | IP Logged Quote kastnblast
Hey, good tip. I'll see about getting into the tail light assembly when I get home from work today. Since things are going to be exposed to the elements a bit, I'm going to get marine-grade plugs/breakers, will be hitting a boat store for that soon.
Thanks again!
