Posted: Feb 10 2005 at 2:03am | IP Logged
mnealp33 wrote:
i ussually do stuff like this myself but i let someone talk me into it ,
Does anyone know if they have came out with the plug and play harness for it yet
If you go to Kragen or your local auto parts store, they should carry the necessary plug. Look under your driver side tail light, there should be a can type plug. It's taped to some wires behind the rear bumper. Pull the cap off and plug in a seven prong (I could be wrong on the seven prong) chevy plug (for sure a chevy plug). If you aren't sure, most autopart stores will let you bring the part out to the parking lot and check. Just leave a credit card and they're cool with it until you actually buy the part.. I it takes all of 5 minutes for the total install. Get the mounting bracket and mount it to your receiver.
I put a six/four prong plug outlet so I don't have to put an adapter for my boat. My boat uses the standard four prong flat bar plug. If I need a circular six prong for whatever I'm towing, its there.
__________________ Smoke XE 4x4 Crew Cab, Prefered pkg, Leer Tonneau, Line-X Spry-on, Hidden Hitch Class III tow.
