danfialek Newbie
Posted: Feb 18 2005 at 9:18pm | IP Logged
just wanted some help from y'all just got a nissan titan (king cab xe)
and i just bought 4 new polk audio speakers for it....just wanted to
know if anyone has a door panel diagram thing to show where all the
panel clips are (dont wanna break em) and what other info you think
might be usefule or unique to the titan (ive done installs before, just
this is brand new and dont wanna mess it up AT ALL....thanks guys
Kennebell Newbie
Posted: Feb 20 2005 at 9:01pm | IP Logged
ok.. There are 5 bolts all toether.. I can't draw up a diagram but can tell you where they are.. the first is by your door handle. there is a small square that you can remove with a flat head or a finger nail.. after that the piece behind it snaps out and there is a second bolt behind that. Up on the actual door handle where it is like a puda color, that snaps out to. Be careful it is plastic. There are two bolts behind it. I find it easiest to use a reallly thin flat head and unsnap it from the bottom. The arm rest also is an unsnapper and yes there is a bolt behind that also. This is the hardest piece to pull off cause there are three hug snaps... Don't worry you won't break that thing. It scared the poo out of me when I did it, on a guess and when I saw those snaps I was like WOAH!!!!! Thats all the bolts and then the door will un snap cause it has those organe snappy things.... Pretty easy once you do it... ANy questions pm me or whatever.. Good luck
__________________ Kennebell
bigbear05 Moderator Group
Posted: Feb 21 2005 at 9:26am | IP Logged
Man, Kennebell I bet your turning radius sucks.
Kennebell Newbie
Posted: Feb 21 2005 at 10:36pm | IP Logged
yea it sure does.. lol.... To bad its just a photochop.... lol.. The truck is stock hight right now, but im putting the 2 4 drop on it as soon as it gets here
04GalaxyLE Newbie
Posted: Mar 03 2005 at 9:01am | IP Logged
I have the RF system & the HU is the only part RF. The
speakers are Clarion. I put some CDT CL-61 Comps up front &
Alpine 1629 out back and it made a world of difference. I had
Best Buy install the Comp's but did the rear myself and it was pretty
easy. There were like 6 or 8 clips and 3 or 4 screws.
__________________ 04 LE King Cab "Galaxy", Vent Visors, Bug Sheild, Tint, CDT CL-61 front speakers, Alpine 1629 Rear, Chrome QX56 wheels
motocruiserbill Newbie
Posted: Mar 07 2005 at 8:39pm | IP Logged
Hey Guys! Do you know that the speakers in the rear are 2 ohm? If you hook up 4 ohm speakers, won't the power be cut in half? I have the regular 6 disc system. I would like to replace the speakers only. Also, you would need to make a special fit for the holes in the door. Regular 6.5's will not line up. THANKS for any help.
