Posted: Mar 15 2005 at 8:53am | IP Logged
Nissan Titan King Cab Extang "Black Max" Tonneau Cover in excellent condition. Used only 2 months. No longer need it. Carefully packed and ready to ship.
Located in MA: $150
http://www.extang.com/docs/blackmax.html
Extang makes the ONLY tonnos that work well in cold climates
- Stud low for tight fit in hot weather
- Slide off, flip over, then slide on again
- Stud high for looser fit in cold weather
- BlackMax—when solid black is the bold good look you want.
- Exclusive patented all-climate engineered design that’s 4-way fully adjustable for cold weather.
- Snaps along cab rail allows quick and easy access into the front of your truck bed.
- NO drilling,NO damage!
- “SpringLock™” bows-easy to install and they’ll never fall off.
- One-finger removal of tail rail using the “LeverLock™” system allows quick access for hauling large loads. No hassles or tools.
- “SnapStopper™” keeps snaps on the rail when tarp is rolled up for bulk hauling.
- The BlackMax features fiberglass reinforced nylon snaps that will not break.
- Best warranties: 10 years on tarp, and lifetime on frame!
- Famous Extang engineering, quality workmanship and excellent customer service.
- Drop tailgate with tonno on.
