Subject Topic: 2005 Titan? Post ReplyPost New Topic
karmasoft
Posted: Apr 21 2004 at 11:09am | IP Logged Quote karmasoft
Hi,
I'm "this close" to buying a 2004 Titan.  Test drove Denali, F150, and Titan.  Titan is far and away the best of the bunch.  I wanted a truck with a tight turning radius, so I started out thinking the Denali would be the way to go.  Ultimately the GM was too long in the tooth however, and just couldn't match all the capability of the Titan.
So I'm all set to buy a Titan, but I realize the 2005's are just around the corner.  I wanted to see if anyone here knows what changes will go into the 2005 Titan?
Thank you,
Karmasoft
Back to Top View karmasoft's Profile Search for other posts by karmasoft
