65Shelby Newbie
Posted: Jun 27 2005 at 10:12am | IP Logged
Hi,
Dull subject here, but I can't find an answer on the internet. Question... How do I restore the white on my raised white letter tires after a couple of scuffs with the sidewalk? I've tried those "crayons" and they don't work. Still getting used to driving such a big vehicle. Thanks,
Scott
Posted: Jun 27 2005 at 3:22pm | IP Logged
Try using Westley's Bleachwhite tire cleaner. It seems to get whats left really white.
Posted: Jun 28 2005 at 10:15pm | IP Logged
IQ9* wrote:
Try using Westley's Bleachwhite tire cleaner. It seems to get whats left really white. |
DITTO ..it works really good..might also try the Clorox gel pen...make sure to wash it all off tho, not sure if it might deteriorate the tire over time...also a brillo pad will work well, but just not too often as its pretty abrasive...keep on truckin
65Shelby Newbie
Posted: Jun 29 2005 at 8:39am | IP Logged
Thanks for the suggestions, I'll give them a try. I've done some experimenting on my own , so far an oil based white paint pen has worked the best for parts of the tire where the "scuff" was the worst.
Scott
phlydude Newbie
Posted: Jun 29 2005 at 3:53pm | IP Logged
try simple green and a plastic bristle tire brush
SAWEET Groupie
Online Status: Offline Posts: 97
Posted: Jul 10 2005 at 9:52am | IP Logged
The white part of the raised letter is actually in the rubber compound. So contrary to what you might think it is ok to spray on some simple green and then use a WIRE brush on the letters and hose off. It will come out perfect! I do it all the time.
Glenn
__________________ Tampa, Florida. 04' CC LE Nav. DVD, Sunroof.
Mods-
65Shelby Newbie
Posted: Jul 14 2005 at 9:05am | IP Logged
Hi Glenn,
I tried your suggestion (simple green and wire brush) works perfectly, thanks!!
Scott
