Subject Topic: Do new Titans have updated brakes? Post ReplyPost New Topic
UGATITAN
Posted: Jun 28 2005 at 8:24pm | IP Logged Quote UGATITAN
I just purchased a 2005 Titan with a build date of 3/05, and I asked
the salesman if the Titans on the lot had the updated rotors and
calipers. Of course he said yes. How can you determine if you have the
new type of rotors?
I love the truck so far!
Back to Top View UGATITAN's Profile Search for other posts by UGATITAN
phlydude
Posted: Jun 29 2005 at 3:54pm | IP Logged Quote phlydude
Anything in March probably doesn't have the fix applied from the factory.  Late March/ early April is when the fix went in place on the line.
Take a look at one of the front rotors.  If the inside surface is thinner than the outside piece, you have the old rotors.  Also, if you have a ton of brake dust, more than likely old set-up.
Back to Top View phlydude's Profile Search for other posts by phlydude Visit phlydude's Homepage
baseballfanz
Posted: Jun 30 2005 at 9:34pm | IP Logged Quote baseballfanz
Mine has a 04/05 built date, there don't seems to alot of brake dust but I will try to measure my disk tommorrow to see if they are even.
Back to Top View baseballfanz's Profile Search for other posts by baseballfanz
