Posted: Jul 19 2005 at 1:47pm | IP Logged
You have to check out Prerunnergreg's (PRG) kits! PRG's kits are the best available for the Titan. A 2.5" kit like the Top Gun kit you mentioned is not recommended for a 4x4 Titan without making other modifications because it is will make your front end higher than the rear (a 4x4 is 2" to level) and will also allow the upper arm to clunk on the coil bucket which will require you to grind down your coil bucket or get a longer arm.
PRG's kits also come with new larger bumpstops to help control the compression and help prevent you from destroying your front shocks.
Go here for pics of my install: http://www.tscomputerservices.com/titan/PRGkit.html
__________________ Havock
Deep Water Crew Cab SE
Big Tow -- Utility Bed -- Off-Road
Born 01/04
PRG 2.5" Front/1.5" Rear Lift
Havock's Titan Page
