305ENG Newbie
Posted: Jul 13 2005 at 8:55pm | IP Logged
I disconected the air cleaner electrical connector while changing the air filter. I forgot to reconnect it before starting the engine. The check engine light came on I turned the engine off and reconnected it. Now the light will not go off. How do I reset the light.
305ENG Newbie
Posted: Jul 13 2005 at 9:51pm | IP Logged
305ENG wrote:
I disconected the air cleaner electrical connector while changing the air filter. I forgot to reconnect it before starting the engine. The check engine light came on I turned the engine off and reconnected it. Now the light will not go off. How do I reset the light.  |
Anybody care to guess. I really don't want to take to the stealership.
Todd TCE Senior Member
Posted: Jul 14 2005 at 2:31pm | IP Logged
Old Ford trick maybe.
Disconnet the battery neg, discharge the capacitors (hit the brake pedal for 5sec) then put the neg cable back on. This reset the Ford EECIV
305ENG Newbie
Posted: Jul 15 2005 at 9:59pm | IP Logged
thanks todd. it worked. no more light. you obviously know more about trucks than just "lift kits and exhaust.".
you the man.
