Subject Topic: Tickin in front passenger side Post ReplyPost New Topic
Figgie_Wiggie
Posted: Jul 21 2005 at 8:39pm | IP Logged Quote Figgie_Wiggie
05-Titan < Hello,  I am experiencing a ticking noise on the front pass. side of truck.  I took it to the dealer and they said it was okay, Please advise if you can help.  to help clarify I have removed the front bud shield.
Thanks for your support,
Figgie_Wiggie-Houston, TX. e-mail, anthonyf@materialmg.com
Back to Top View Figgie_Wiggie's Profile Search for other posts by Figgie_Wiggie
Posted: Jul 21 2005 at 11:53pm | IP Logged Quote thepuffman
Someone on here had a clicking sound coming from that direction..finally figured out it was something to do with the seat belt???  ....GL
Figgie_Wiggie
Posted: Jul 22 2005 at 9:18am | IP Logged Quote Figgie_Wiggie
Well, I try to lock in the pass. seat beat..  Both the service manager & I were schocked, we could not find that damn ticking.  Service lifted the truck & had it for two days, & could not fing anthinyg wrong, and the problem still persits.   Please help.......
Posted: Jul 23 2005 at 12:44am | IP Logged Quote thepuffman
see if this thread helps
http://nissantitan.info/forum_posts.asp?TID=806&KW=seat+ belt&TPN=1
alaskanspawn
Posted: Jul 29 2005 at 2:42pm | IP Logged Quote alaskanspawn
The ticking noise may not be the seat or seatbelt.  I have posted this before but can't find my own post.  It may be the air conditioner unit bolts.  There are washers on the bolts and if the bolts aren't tightened well enough you get a small ticking noise...almost sounds like an electrical tick.  Have them check those washers.
2004 Titan 5.6SE
Born on 11/03
FlatBlack
U.S. - Arizona
Posted: Aug 01 2005 at 11:16am | IP Logged Quote FlatBlack
As most of us TITAN owners know of your dismay. I had to take the dash down and tighten all of the hardware under it. ALSO, there is a grounding issue with our ignition coils. They will short to ground and make a ticking sound. adding a larger ground wire to the exsisting ground strap on the head on the passangers side will eliminate that tick. My heater motor worked loose and made a ticking sound when it started and when I hit a bump.
 So many noises, and so few patience left. I just gave up on them all.
My Precious
Born 06- 04 Adopted 08- 04
Back to Top View FlatBlack's Profile Search for other posts by FlatBlack
