Subject Topic: Titan Stock Stereo System Post ReplyPost New Topic
EasyRider
Posted: May 26 2004 at 6:25pm | IP Logged Quote EasyRider
Back in March, when I talked to a sales rep at Good Guys, he said that the Titan's stereo was linked to some of the electronic systems, and could not be replaced. A after market stereo would have to be installed independant of the Titan's systems. Was he telling the truth or just full of hot air.
My dealer hasn't got back to me with a reply.
I have the Six disc cd changer, not the rockford setup.
Back to Top View EasyRider's Profile Search for other posts by EasyRider
Posted: May 26 2004 at 8:21pm | IP Logged Quote EvilPeppard
I don't know for certain, but maybe you could call a place like Car Toys (or some other reputable stereo installer in your area) and see if they have any info.
I sure would think they could figure something out.
Let us know.
duckslayer30
Posted: May 31 2004 at 5:39am | IP Logged Quote duckslayer30
look it might take some extra wires like in the ford taurus half the radio is in the trunk but its possible and if it is a problem metra will make the harness for it
Back to Top View duckslayer30's Profile Search for other posts by duckslayer30
NISSANONE
Posted: Jun 09 2004 at 11:17am | IP Logged Quote NISSANONE
IT IS POSSIBLE BUT YOU HAVE TO LOOK HARD AT THE WIRING DIAGRAM DUE TO THE  ..SOUND VOL. CONTROL..CUZ IT IS SPEED RELATED ON TURNING YOUR SYSTEM UP AND DOWN... ON THE FADE PROBLEM I HAVE CALLED TECH LINE AT NISSAN AND THEY HAVENT GOT A FIX YET!
04 TITAN SE...HEMI EATER
Back to Top View NISSANONE's Profile Search for other posts by NISSANONE
JBWilkins
Posted: Jun 30 2004 at 12:56am | IP Logged Quote JBWilkins
I know of several people who have replaced the system.....the problem you run into is the dash panel itself......you can order a version of this panel for the Armada that has a double DIN opening and slip any aftermarket radio in (you just need a filler for the other part)....I think the Good Guy was just clueless........now if you have the rear seat controls...you will lose that......and the steering wheel controls unless you find an adapter for them (which does exist just can't remember from where)...............
Back to Top View JBWilkins's Profile Search for other posts by JBWilkins
