Subject Topic: Oil filter removal Post ReplyPost New Topic
TRUCKIN
Posted: Feb 28 2006 at 6:04pm | IP Logged Quote TRUCKIN
Looks like I will have to take off the skid plate under the oil filter to get to it...
Is there an easy way or do I just start removing bolts.....
Steve....06 KC
Back to Top View TRUCKIN's Profile Search for other posts by TRUCKIN
eanderstxtitan
Posted: Feb 28 2006 at 10:19pm | IP Logged Quote eanderstxtitan
It's actually not as bad as it looks.  I think six 10 mm bolts is all.  I used a cordless drill with a 1/4" socket and it went fast.  You don't have to jack the truck up to get under it, but it might help a little.  I always changed my oil filters each oil change - until my last one on my Titan.  I've always heard/read that you should change the filter every other oil change anyway.
Titan XE - Plain Wrapper
Power + Luxury or Economy? I made my choice!
Back to Top View eanderstxtitan's Profile Search for other posts by eanderstxtitan
chokoy
Posted: Mar 01 2006 at 8:47am | IP Logged Quote chokoy
does the type of filter matters? i use fram on mine. i change filter every oil change too. what's a good filter anyway?
JoeyCrack
Posted: Mar 01 2006 at 1:46pm | IP Logged Quote JoeyCrack
just on principal i always change the filter even on the VWs I owned that the mileage rating on the filters was much longer I never let them go more then one change.  As for the skid plate there is a trap door which makes it very easy to access.  If its your first filter change though have fun getting it off!  I think they hired someone from the worlds strongest man to put the thing on.
Loving All Things Titan
miserytom
Posted: Mar 01 2006 at 5:51pm | IP Logged Quote miserytom
if u have the off road package skid plate the entire thing does not need to be taken off, theres a small panel with 4 allen screws , just take that small panel off and u can get to ur filter through there....
TRUCKIN
Posted: Mar 01 2006 at 6:44pm | IP Logged Quote TRUCKIN
Thanks for the replys folks.....
I have the tow package but not the off road package.....
I will take a look for that little trap door which I hope is there,
or I will have to take off the 10mm bolts.....
The oil filter would be in trouble for damage if it were not for that skid plate...
Steve....06 KC
JoeyCrack
Posted: Mar 01 2006 at 7:21pm | IP Logged Quote JoeyCrack
given the ride height of the titan i'd say the filter is likely fine at its present height even without the plate.  I had a VW GTi that rode very low to the earth and never smacked that so i doubt it would be an issue here
Posted: Mar 01 2006 at 9:46pm | IP Logged Quote thepuffman
I have the Big Tow..my entire skidplate must be removed to reach the filter ...is easy though...just 4 bolts....I thought the little drip plate was a nice feature. I have only used OEM filters so far..is a hassle to go get them at times but I got to go to the dealership to get the darn crush gasket anyways....
miserytom
Posted: Mar 04 2006 at 7:35am | IP Logged Quote miserytom
you can order those crush gaskets at www.courtesyparts.com which is a nissan dealer...  heres the link for a 10 pack  http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=P ROD&Store_Code=CP&Product_Code=11026-VK56DPK
as for filter damage, there are other main suspension parts you'd kill before the filter ever got hit lol
