TITAN326326 Newbie
Posted: May 01 2006 at 4:19pm | IP Logged
Any thoughts about the new EEG 85% Ethanol gas W/15% gasoline added to it. In some states ie--Florida for example there are no stations that have Ethanol. We, here in South Dakota mainly have the ethanol added to the gasoline in a small % useable for regular engines since it takes a special engine strickly formulated for the EEG type fuel. I know the Titan for 2005 was avaiable with that sort of engine.
__________________ This is the message we have heard from Him and announce to you, that God is Light, and in Him there is no darkness at all.
miserytom Senior Member
Posted: May 02 2006 at 2:42pm | IP Logged
its not the engine that is differant really, its the fuel lines, pump and other little stuff like that
TITAN326326 Newbie
Posted: May 02 2006 at 3:09pm | IP Logged
I stand corrected. I also should have called it E85, not EEG 85, not sure where I got that.
Posted: May 04 2006 at 12:34am | IP Logged
we know what u meant lol
fox92020 Groupie
Online Status: Offline Posts: 56
Posted: May 25 2006 at 1:02pm | IP Logged
I have heard that when you run the E85 you get half the gas mileage you normally get. Is this true? There is only one station in San Diego CA with E85
TITAN326326 Newbie
Posted: May 26 2006 at 10:00am | IP Logged
I don't think it is half the mileage with E85 but it is less, how much less I'm not sure. It would be worth looking into.
ttugrad95 Newbie
Posted: Jun 02 2006 at 4:31pm | IP Logged
Fuel milage is less but you get a little more HP. E85 is a little cheaper but not much due to the current shortages of ethanol. Those who have used it claim it ends up costing more per mile. The reason MPG is low is because a flex fuel vehicle is only ethanol compatible, its not optimized to run on it. If it were I'm sure the opposite would be true with gasoline. You find stations that carry it and more info on ww.e85fuel.com.
TITAN326326 Newbie
Posted: Jun 02 2006 at 6:24pm | IP Logged
I just went to www.e85fuel.com and they answer some questions & have good information. Thanks. They have a Q & A there among other information offered.
