Subject Topic: Low Beam Bulb Replacement Post ReplyPost New Topic
paul in nwa
U.S. - Arkansas
Posted: Jul 16 2006 at 5:35pm | IP Logged Quote paul in nwa
Trying to replace stock bulbs with others.  I can get to high beam and fog lights but trouble getting to the low beam.  Looks like the light assembly needs to come out.  There is a snap in connection on the inboard side of the assembly I don't see how to release.  Does it take a special tool for release?
pg in nwa
Back to Top View paul in nwa's Profile Search for other posts by paul in nwa
miserytom
Posted: Jul 17 2006 at 1:25pm | IP Logged Quote miserytom
you do NOT have to take the entire light assembly out, take apart the front half of your wheel well plastic, u can get to all the bulbs from there , theres only 1 screw and 2 little pop snap thingys u need to undo to pull the plastic back enough to slip your arm in there
Posted: Jul 17 2006 at 8:04pm | IP Logged Quote thepuffman
You can go here :
http://maxhawk.bravepages.com/misc/titan_bulbs.pdf
and go through alot of B.S. removing the front grill, or you can save yourself some time and do like Tom suggests and just go in thru the plastic wheel wells...just be careful not to touch the new bulbs with your fingers..I use latex gloves...gl...keep on truckin.
paul in nwa
U.S. - Arkansas
Posted: Jul 17 2006 at 8:43pm | IP Logged Quote paul in nwa
Thanks to both for your help.  You saved me time and effort.
pg in nwa
