Subject Topic: Oil useage?? Post ReplyPost New Topic
jmcgough98
Posted: Oct 29 2006 at 7:52am | IP Logged Quote jmcgough98
I change oil every 3-4000k miles on my 2004 titan. Around 2,500 miles into cycle I notice slight valve tap so I check oil. When I pull dip stick oil level is below low mark and I have to add 2 to 2 1/2/Qts. This has been occuring for as long as I can remember. No oil leaks on my garage floor and never smell anything burning or see smoke. Can anyone offer any thoughts on why this is occuring. Is this common in big V-8's. I have only had 4 and 6's in cars and never went thru oil.
Also, for such a hugh engine what up with the tiny oil filter. Is there a work around on this or is the little filter OK??
Nonetheless the truck runs great. Only problems have been brakes and passenger window.
Back to Top View jmcgough98's Profile Search for other posts by jmcgough98
Posted: Oct 30 2006 at 8:05pm | IP Logged Quote thepuffman
I agree the little filter looks puny, but rest assured...its the right one...As for the oil usage...NOT!! ..After an oil change and running it a few minutes, you might need to add a piece of a quart, but it shouldnt be "using" any oil and certainly not 2 + quarts. Its goin somewhere ...no drips in the driveway? ...hmmmm
chokoy
Posted: Oct 31 2006 at 7:26am | IP Logged Quote chokoy
nyahhahahahahahhaha... checked my truck and we have the same problem hehehehahhahaa..are you going to bring it to the dealer for a fix? please post any update
