Subject Topic: Dash Kit Post ReplyPost New Topic
Klipse
Posted: Jul 10 2004 at 5:52pm | IP Logged Quote Klipse
New Titan owner, well got it about a month ago.  Silver King cab, almost fully loaded.  I cant stick with a stock truck for long, I am going to tint, and put new sound system in. Replace all factory speakers with Mb Quartz and add 2 10" jl w6v2's under backseats..... My only problem I am running into is that the dash is a solid piece, and I dont want to pay and arm and a leg for fiberglass work.   Does anyone know if there is a dash kit out?????   Thanks   kyle
Back to Top View Klipse's Profile Search for other posts by Klipse
Zoback
Posted: Jul 11 2004 at 9:54pm | IP Logged Quote Zoback
i saw one at http://www.courtesyparts.com/titan/interior.html which is just a empty console which any good car audio place can fabricate another kit to make it fit.  You also want to be careful with MB Quart because they were recently bought by a bigger company and the quality has decreased a lot.  If I were you, I would put a/d/s speakers instead and put one 10w7 instead of two w6's.  You won't lose all of your storage and the sound will be as good or better than two w6's.
Titan LE KN, Banks, JBA headers
Back to Top View Zoback's Profile Search for other posts by Zoback
Klipse
Posted: Jul 15 2004 at 6:08pm | IP Logged Quote Klipse
Thanks for the input about mbquartz.  what is a/d/s??    I think that the w7's need need to much air space.   or they are just to big, as far as mounting depth.........   I was going to run 2 w6's with 2.4 farad cap, and 2200 watt amo at 4 ohms which will put it at 400 watts per,  and sub doesn't actually push what it says..
CocoaBeachDan
Posted: Jul 15 2004 at 8:02pm | IP Logged Quote CocoaBeachDan
Any competent local Nissan dealer's parts department should be able to order the part for you. Ask for the Cluster Lid Assembly for a Titan XE. The Nissan part number should be 68260-7S000 (at least that what it says on my box).
Good Luck !
Dan
Back to Top View CocoaBeachDan's Profile Search for other posts by CocoaBeachDan
Klipse
Posted: Jul 16 2004 at 3:33pm | IP Logged Quote Klipse
Thanks man, that solves one problem
