Subject Topic: freaky transmission Post ReplyPost New Topic
Mitch
Posted: Aug 09 2004 at 11:53pm | IP Logged Quote Mitch
Went out to my Titan after work today to go home started it up and put it into drive and it felt like it clunked into gear. I took my foot off the brake and gave it gas and it would barely move. I put it into reverse and backed up with no problem. I tried drive again with same result. I put it into park, turned it off and started looking for the roadside assistance number and decided to try it again. Well I started it put it into drive, went into gear and seemed to drive fine. Shifting from 1st to 2nd seemed to hesitate a little. Should I take it into the dealer?
Mitch
djrickp
Posted: Aug 10 2004 at 8:57am | IP Logged Quote djrickp
I would.
Rick P
04 Titan CC LE
Big Tow
Back to Top View djrickp's Profile Search for other posts by djrickp
silverbullet
Posted: Aug 10 2004 at 9:45am | IP Logged Quote silverbullet
YES!
Back to Top View silverbullet's Profile Search for other posts by silverbullet
Vostok
U.S. - Nebraska
Posted: Aug 10 2004 at 10:37am | IP Logged Quote Vostok
Sounds like a dying tranny almost. Either that or somethings wrong with your Tranny inside.
Back to Top View Vostok's Profile Search for other posts by Vostok
Mitch
Posted: Aug 10 2004 at 1:02pm | IP Logged Quote Mitch
I thought it sounded like the first gear solenoid not engaging all the way and the computer getting confused. Putting the truck back into park and turning it off the engine reseted the computer and cut power to the solenoid closing it. The engine check light did not come on so Im certain no codes were thrown.
I called the dealer and they said I could bring it in but if no codes are thrown and it drives good then they have to real insight unless it does it there. They said if it happens again bring it in for sure.
Mitch
Austin_Z_dude
Posted: Aug 10 2004 at 3:31pm | IP Logged Quote Austin_Z_dude
I had a similar clunk noise when shifting into gear.  This was after doing some fairly light towing.  I wouldn't wish tranny problems on anyone.  I had to give up my Titan because I lost confidence in it.
Longtime Nissan/Infiniti owner.
Back to Top View Austin_Z_dude's Profile Search for other posts by Austin_Z_dude
