Posted: Nov 29 2004 at 7:24pm | IP Logged
Tough Titan wrote:
Buster,
The LT285/65R18/D you want is actually the same diameter as the stock tire but maybe a half inch wider. So, yes, it would fit without problems.
Check out this web site for the comparison: http://www.miata.net/garage/tirecalc.html
Hope this helps!
Well I ended up going DOWN to a 17X8 Eagle Alloy rim to fit some 285/70/17 Mudterrains under my fender and even with that the tires are rubbing the inner fender. I'm installing my prerunner 2.5" lift kit to get rid of that but Its going to be interesting getting those in there on 18" rims. I even tried cutting out some of the inner fender and removed the mud flaps and it still rubs on the turns. Good luck man..
BTW pics of my truck pre-lift
ok go to http://members.cox.net/w.suarez/
__________________ 2k4 350Z: Turbonetics Single Turbo Kit, Apexi WS2 Exhaust, B&G Springs, Hotchkis Sways, Mossy Short Shifter, Alpine/JL system
2k4 Titan SE: JL/US Amps system
