Qship Groupie
Posted: Dec 12 2004 at 11:13am | IP Logged
Any suggestions on how to remove a stubborn oil filter? The filter is pretty banged up after my futile efforts.
It simply has not budged. I've already drained the oil and I'm not sure if the filter has a hole in it.
Thanks in advance!
ssj3 Newbie
Posted: Dec 12 2004 at 8:47pm | IP Logged
I usually just poke a screwdriver throught the filter and turn it.
Johnboy Senior Member
Posted: Dec 12 2004 at 9:15pm | IP Logged
Is this the first oil change? If so NISSAN overtightened the filter and you should bring it to the dealer to get it changed.....
__________________ Johnboy
Posted: Dec 12 2004 at 10:27pm | IP Logged
On my first oil change I think I made a mistake by doin it myself. But same as you, my filter was on so tight I had to use one of those rubber strap wrenches...I also had to cut most of the plastic handle off so that I would have enough room to turn it. But it was still enough leverage to loosen the filter...finally..I thought of the the ole screwdriver trick but I was afraid to punch a hole in it...I figured if worse came to worse Id fill it back up with oil and drive it to the dealer...GL
BTW I got the strap wrench at Harbor Freight...for like 2 for $6, so I didnt feel too bad about cutting the handle off. If it had been a $20 craftsman I prolly would have just driven to the dealer....Also up until this last scenario I just described, I had always had good luck gettin filters off using a rubber glove...works in tight spaces and always provided enoughed grip to spin them off.
koncept Newbie
Posted: Dec 13 2004 at 2:52pm | IP Logged
i use the trusty hammer and screwdriver to puncture it then turn it out, has worked every time ive had a stuborn filter
Posted: Dec 17 2004 at 5:59pm | IP Logged
I actually ordered a special oil filter wrench for my Titan.
My Titan and my wife's Maxima both have small filters. The oil
filter wrench I got fits the filter correctly and has a swivel neck to
get in at an angle.
Posted: Dec 18 2004 at 12:04am | IP Logged
Sounds neat..I guess you still have to remove the skid plate?? where you get the wrench ?
dale Newbie
Posted: Dec 18 2004 at 4:49pm | IP Logged
When you change your oil it's very important to put a film of oil on the gasket of the new filter to be installed. It makes it much easier to remove on your next change.
RI Xterra Moderator Group
Posted: Dec 18 2004 at 5:24pm | IP Logged
Also Nissan uses crush washers on the drain plugs that require changing at every oil change...
Todd TCE Senior Member
Posted: Dec 19 2004 at 9:43am | IP Logged
Big channel locks.
