Subject Topic: Oil Filter Part Numbers? Post ReplyPost New Topic
camino70
Posted: Dec 21 2004 at 5:26pm | IP Logged Quote camino70
I am a big fan of purolator pure one oil filters and recently used the stock replacement for my oil change.  Next change, I would love to use a slightly larger filter.  The stock and stock replacement can't really be meant for the 5.6, it is way to small!!!
TIA,
Ron
'04 Canteen LE 4X4 no packages, no mods, yet...
Back to Top View camino70's Profile Search for other posts by camino70
camino70
Posted: Mar 08 2005 at 7:08pm | IP Logged Quote camino70
Anybody else use Purolator Pure One?
CanteenGrnTitan
Posted: Mar 29 2005 at 7:02am | IP Logged Quote CanteenGrnTitan
I do.  Noticed it is small, too - Nissan and Infiniti use the same filter for almost all their vehicles...I guess they know what they are doing???
Back to Top View CanteenGrnTitan's Profile Search for other posts by CanteenGrnTitan
stitch
Posted: Mar 29 2005 at 12:51pm | IP Logged Quote stitch
Use the same Nissan filter that came off of it. These are very good quality filters and have the correct anti drainback valve settings. Anything else may be a compromise to fit many applications.
P1's ,Mobil 1's, K&N's are all good but the Nissan filter has similiar heft, correct gasket,good media and reasonable (but not cheap) price.
Bottom line is it's good,it works, has been tested with that motor and in the event something goes wrong---- it's one less thing for Nissan to point a finger at.
Kevante
U.S. - Arizona
Posted: Mar 29 2005 at 7:12pm | IP Logged Quote Kevante
what other filters can be used?
CC LE Galaxy Black
Todd TCE
Posted: Apr 07 2005 at 10:11pm | IP Logged Quote Todd TCE
Next change I'm on a mission to fit a larger volume K&N. I'll post the part number when done. If nobody has done so.
And as I've mentioned before; 'anti-drain back' is pretty worthless on this motor. Unless you park upside down...I don't know of a filter today which does not have this basic feature- it's the flapper you see under the small holes.
