Posted: Feb 01 2005 at 12:25am | IP Logged
Does anybody know how to easily remove the front skid plate on the Off Road? I have a grill mod I am putting in and the bottom grill piece requires that I remove the skid plate using a 10mm wrench. But I found out that on the Off Road pkg that the skid plate uses a 8mm hex wrench, or Allen wrench. Plus, there's like 4 bolts in the front that keep it on. It may be that the weather is mighty cold, or I'm just a weaker than I thought.
