Posted: Feb 18 2005 at 10:22pm | IP Logged
your only option is to rewire the lights to a direct power source other than the switched source from the BCM (such as the battery). You would have to install an aftermarket switch as well, basically making them function on their own.
You can't make it work with the factory switch without a reprogram of the BCM I am told. The switch lever is all electronic so there's not even a way to rewire it to make this work. Sorry.
__________________ 2004 Titan SE Kingcab
-Smoke Gray
-Big Tow Package
