Posted: May 24 2005 at 4:52pm | IP Logged
Two schools of thought on that. One says drive like you stole it and the other says not to. Forget about it.
I would refrain from towing anything for a while and immediately check your rear diff fluid. Many in 04 had low fluid out of the factory. These Titan Dana rears are very "tight" from the factory and build a significant amout of heat and wear-in materials during the first 1000-2000miles. Plan on changing your rear diff fluid during that time and use synthetic.
