Posted: Jan 09 2006 at 5:27pm | IP Logged
LATitan1 wrote:
I am having a little problem removing the steering wheel column trim pieces. I am adding fog lights to my truck and it requires changing out the light switch in favor of a new one, the only thing is that I can't get the trim pieces removed. I have removed the 3 screws and the trim must snap together somewhere but I don't want to break them so I am in need of suggestions on how to remove the trim the best way. I have a 2006 Nissan titan with center console shifter. Thanks for the help... |
Sorry for the late reply, I assume you are done by now, but I added the same fog light kit to my truck. Mine came with pretty specific instructions on how to remove the trim piece. Dont pry on it though, as I recall it had a tip/trick to it though...GL
