Subject Topic: Active Headrest Post ReplyPost New Topic
Islandiver
Posted: Apr 03 2006 at 9:27am | IP Logged Quote Islandiver
Does anyone know exactly what an active headrest is?
Back to Top View Islandiver's Profile Search for other posts by Islandiver
Posted: Apr 04 2006 at 11:25pm | IP Logged Quote thepuffman
I think it means that it pivots during a collision to help prevent neck injuries....anyone know if this is correct??
TRUCKIN
Posted: Apr 05 2006 at 6:06pm | IP Logged Quote TRUCKIN
The Active Head Restraint effectively helps reduce the force acting to bend the neck backward in a rear-end collision. It reduces the resultant bending force by approximately 45%.
The Active Head Restraint uses the force of the occupant's body against the seatback in a rear-end collision to move the head restraint forward instantaneously to support the head, thereby helping to reduce the impact to the neck of a front-seat occupant. The mechanism of whiplash injuries closely involves two factors resulting from the impact: the force acting to bend the neck backward and the force that causes the head to tilt rearward. Because the Active Head Restraint is effective in controlling these two factors, it can help reduce the load on the neck at the moment of the collision
Steve....06 KC
Back to Top View TRUCKIN's Profile Search for other posts by TRUCKIN
