Posted: Jun 14 2004 at 10:56am | IP Logged
I've had my SE Crewcab RWD since March and already have had a few issues. Just wondering if others have had similar problems. (1) Alignment: truck pulls extreme right. It costed me 3 trips back and forth to convince the dealer to re-align. They finally did it correctly. (2) The coating or paint on the steering wheel plastic inserts where the Volume/Cruise Controls are located is wearing off after just month and half in, without sharp finger nails. (3) The driver front window circuit would cut off the juice to the motor if the switch (auto-up) is activated rapidly and let go of the switch. It would take 3-10 seconds for the circuit to reset and the motor to activate again. I had the dealer looked into this and the motor replaced. Apparently after they had replaced the motor, and I came back again for the same problem, I was given an explanation that it was inherent in the design to protect the motor from frying. This cannot be reproduced on the other (passenger) window!@! The 350Z also has the same inherent design, as I was told. My 2000 Maxima does not have this issue!@
Also does anyone know where I can get a set of cool-looking (not too expensive) running boards for the Titan, other than those offered by Nissan? I would love to check it out. Keep trucking...
__________________ Mytruck04
