Subject Topic: Rear end - what type? Post ReplyPost New Topic
sasilverbullet
Posted: Jul 14 2004 at 7:41am | IP Logged Quote sasilverbullet
LE with Tow Package, anyone know what kind  of rear end we have?  limited-slip, standard, etc...
Back to Top View sasilverbullet's Profile Search for other posts by sasilverbullet
sasilverbullet
Posted: Jul 14 2004 at 3:32pm | IP Logged Quote sasilverbullet
I found my answer in the manual.  It's a normal rear-end, and needs 80-90w.  I'll be putting in Mobil 1 synthetic gear lube.
CocoaBeachDan
Posted: Jul 16 2004 at 10:13am | IP Logged Quote CocoaBeachDan
All Titans with the Big Tow Package include Vehicle Dynamic Control. Part of VDC is what Nissan calls ABLS (Active Brake Limited Slip). If you have wheel spin on one wheel wheel, ABLS applies the brake to just that individual wheel, transferring the power to the other wheel.
A later option is the Electronic Locking Differential. This was an afterthought in the Titan. The decision was made to add it after talking with focus groups and realizing that so many current truck owners had it in their head that it had to have "limited slip" that they could not grasp the concept of ABLS. Nissan was affraid some buyers may stray if they could get a 'good 'ol lockin diff".
The VDC / ABLS is newer technology. VDC alone is worth the cost of the Big Tow Package even if you never plan on towing anything.
Dan
Back to Top View CocoaBeachDan's Profile Search for other posts by CocoaBeachDan
Stomper4x4
Posted: Jul 16 2004 at 4:09pm | IP Logged Quote Stomper4x4
what I heard was that the LSd rear comes newer Off Road package.
(not the big tow) and that VDC can not work with the LSD so you
loose the VDC. The LSD rear was a delyed release. Not sure if they
still offer both set ups or they have just done away with the VDC Off
Road Package all together. Some online souce show two available Off
Road Packages other only show one. For the record VDC is not very
high tech or new. All it does is apply the brakes to spinning wheels.
It's a better setup for the street and light off roading. LSD is better for
hardcore offroading.
King Cab LE
Back to Top View Stomper4x4's Profile Search for other posts by Stomper4x4
Todd TCE
Posted: Jul 16 2004 at 9:07pm | IP Logged Quote Todd TCE
Anyone else feel there is excessive back lash in the ring and pinion?
I feel it when I pull away from a stop. Somethings not quite right there.
Rear end problems? U joints?
CocoaBeachDan
Posted: Jul 16 2004 at 10:13pm | IP Logged Quote CocoaBeachDan
Attached is a copy of the official Nissan model guide for July. This is the document dealers use to prepare and place their order.
http://www.sutherlinonline.com/modelguide.pdf
The Titan starts on page 12.
Note there are now two Off Road Packages and two Tow packages for the 4x4. The differences being that one (of each) has the ABLS (part of VDC) and the other has the Locking Diff.
Dan
syntrix
U.S. - Nevada
Posted: Jul 17 2004 at 12:52am | IP Logged Quote syntrix
Anyone successful in turning the ABLS off?
It does NOT turn on off on my SE CC with Big Tow.
VDC WILL turn off and will be indicated on the dash by lit "VDC OFF" inducator, and I'll still get the "spin" indicator flashing like crazy on the dash when I break around a corner. It'll even pull the throttle back. Well, I'm guessing it's the ABLS becuase it's modulating the rear wheels and the DBW throttle.
Back to Top View syntrix's Profile Search for other posts by syntrix Visit syntrix's Homepage
1951 Chevy
Posted: Nov 08 2005 at 10:35pm | IP Logged Quote 1951 Chevy
VDC is great news to me!  I think I have a tow package on my '05 LE 4X4.  I was thinking I wished the guy who ordered this truck would have order the electronic locking diff, but after reading this if I have VDC I'm very happy.
How can I find out what exactly this truck has for tow package?  It does have a transmission temp guage, the larger mirrors, a receiver hitch mounted?
Started with a 1951 Chevy, now I've got a '05 Titan LE 4X4 Crew Cab Tow!
Back to Top View 1951 Chevy's Profile Search for other posts by 1951 Chevy
sonnytimes
U.S. - South Carolina
Posted: Nov 14 2005 at 11:07am | IP Logged Quote sonnytimes
One way to tell if it has the electronicly locking differential is to look under the truck. It will have some wires going to the center of the rear end. Most 4X4 trucks with the off road package has this.
