Subject Topic: Bed sliders Post ReplyPost New Topic
jdwtitan
Posted: Nov 03 2004 at 3:39pm | IP Logged Quote jdwtitan
Has anyone figured out a good way to secure the bedsliders so that when you stop and go they don't bang against the bed?  This makes SoCal stop and go traffic even more annoying
Jason
04 Titan LE CC Galaxy Black
San Diego, California
Back to Top View jdwtitan's Profile Search for other posts by jdwtitan
stitch
Posted: Nov 03 2004 at 3:57pm | IP Logged Quote stitch
I threw in a rubber bed mat which stopped them from sliding. If it wasn't for that I would have probably tried heating the very rear of the plastic slider and closing it up some. Just enough so it has some drag and will not freely slide.
jdwtitan
Posted: Nov 03 2004 at 4:30pm | IP Logged Quote jdwtitan
Thanks...  have you have an issue with your factor bedliner?  mine is almost completely white, either from sunbleaching or hardwater spots.
Jason
stitch
Posted: Nov 04 2004 at 8:44am | IP Logged Quote stitch
I looked at another LE before I ordered mine. I had the "drop in" bed liners in two previous trucks and sure you could pitch in cinder blocks with no worry. The drop ins' are thick and have their own structure. They have downsides too,trap moisture and can wear the paint away in some areas
These spray in liners - especially Nissans are (in my mind) just cosmetic. If you pitch in a cinder blocks you'll probably dent the bed. I consider mine nothing more than a anti-scuff coating.
I have the sliding bed divider and the extender. I was able to find a reasonably thin rubber bed mat by 'Driver Design' that fit my KC perfectly AND was thin enough to allow the divider to slide freely, my mat is only about 3/8" thick. Cheap too @ around $70
Cronus
Posted: Nov 04 2004 at 12:22pm | IP Logged Quote Cronus
I put two of the securing "caps" at the very front of the rails. The bedsliders hit the tailgate just a bit but no more sliding.
My Titan @ SLLAR.com
