mrb627 Newbie
Posted: Jul 28 2005 at 1:57pm | IP Logged
Did anyone get the dealer installed satellite radio in their 05
Titan? If so, where is the antenna installed? Is there an
external wire running to the antenna or is it hidden?
Malcolm
bigbear05 Moderator Group
Posted: Jul 28 2005 at 2:02pm | IP Logged
All of the 05's I have seen with it installed have a self-adhesive patch with a small antenna mounted to the rear window on the drivers side. Maybe someone that has it dealer installed can chime in and help you out on this one.
mrb627 Newbie
Posted: Jul 28 2005 at 2:06pm | IP Logged
Thanks BB, I have seen that too but didn't know if that was the dealer
installed method for the antenna or a novice attempt.
