Posted: Aug 17 2005 at 9:40pm | IP Logged
That's what I hate about audio salesman. They sale, they don't work on them. Anyone who knows a good amount about electrical, and electronics knows this. So here's how to help you out.
Ohms is actually a measurement of resistance. In other words, how much stuff is in the path of the power going from the amp to the subwoofer. When the power wire is coiled around to create the subwoofer's magnet. It causes a certain amount of resistance. This is where you get your 2,3,4,8 ohm subwoofers.
Dual voice coils, have 2 sets of wires for the magnet. If each set puts out 4 ohms, then together the subwoofer is a 8 ohm.
Now to explain why upgrading would be pointless, and how changing your current wiring will "increase" your power.
Subs can be wired 2 ways. Series and Parallel. Series -
Parallel -
Now, to show WHY you can get an increase wiring a certain way.
As most everyone knows, the smaller the resistance, the better. Same is true here. The smaller you can get your resistance, the smoother, and louder your system will operate.
Since you have 2 Subs, I'll show how you can get better performance with those.
1.) When wiring in SERIES, you are combining the resistance of the subs. In this case, 4 ohms + 4 ohms= 8 ohms. There's a formula you can use to see exactly how much each sub would get. But I'll give you the basic version now. This is for a 100x2 channel amp. This case the amp puts out 100 watts @ 4 ohms. Now, since your wiring is actually 8 ohms... the power output is 50 watts. So each sub will only get 25 watts.
2.) PARALLEL wiring actually divides up the resistance in the circuit. so your now 4 ohm subs will be running at 2 ohms at the amp. But your power is also divided up. But there's more power to divide up. Here's WHY. Lets say that same amp above is 2 ohm stable. Since your halving the impedance, your power rating is doubled. so that 100 watts @ 4 ohms, is now 200 watts @ 2 ohms. And each subwoofer will be getting 100 watts.
This is why so many people try getting 1 ohm stable systems. The amp puts out more power, because of the less resistance. Also, the amp doesn't have to work as hard to keep pushing the power.
But the power all depends upon the rating of your amp. If your amp is not rated for 2 ohm STABLE, it will do you no good. Same thing with 1 ohm systems. If you have the wiring setup for 1 ohms, and your amp isn't, your not getting the full potential power.
This is a lot to absorb, that's why I thank the following site for the pictures. Refer to it as you need. http://www.termpro.com/articles/spkrz.html They also gave me the idea for the amp rating.
Let me know if you have anymore questions.
