teejake Newbie
Posted: Sep 10 2005 at 8:33pm | IP Logged
Wondering if anyone else has a problem with a dealer installed XM radio cutting in and out? Had XM in my Tahoe and in my wife's suburban and the only time they lose the signal is when we pull in the garage. Any idea if there is a way to fix this?
bigbear05 Moderator Group
Posted: Sep 12 2005 at 2:52pm | IP Logged
Do you notice it cutting out while heading south? If so the antenna may be installed wrong. This link is for the Armada but I don't know if it would have anything to do with the Titan, They do tend to use alot of the same parts. Check out this link to the proper installation of the antenna.
http://www.nissanhelp.com/Ownership/Bulletins/Nissan/2005/NT B05-061.htm
Hope this helped. If not I would take it back to the dealer and have them look at it.
teejake Newbie
Posted: Sep 13 2005 at 9:20pm | IP Logged
Thanks, checked it out and it looks like they put the outside part of the antenna on upside down just like the bulletin warns against. Guess I will be headed back to the Nissan dealer to get it fixed.
