Subject Topic: AUX Volume Post ReplyPost New Topic
jdwtitan
Posted: Aug 02 2004 at 11:11am | IP Logged Quote jdwtitan
I've had my Titan for a week and the only complaint so far is the AUX input (XM/MP3) volume level seems to be about half the volume of CD/Radio/Etc.
Does anyone else have this problem?
Jason
Back to Top View jdwtitan's Profile Search for other posts by jdwtitan
CGreenTitan
Posted: Aug 02 2004 at 1:26pm | IP Logged Quote CGreenTitan
I believe that this is the case for all. I'm sure that since this is an AUX input and you could connect many different output sources to it, the input was attenuated to keep from overdriving it.   So it will depend on the signal level of the device that you are using to determind the vol level you'll need to listen to it.
It gets somewhat loud when switching from AUX to CD if you forget to turn down the vol
2004 KC SE Canteen Green
Big Tow
Utility
RF
Back to Top View CGreenTitan's Profile Search for other posts by CGreenTitan
djrickp
Posted: Aug 02 2004 at 1:38pm | IP Logged Quote djrickp
I thought it was just me.  I had to turn my XM radio output to its highest setting, but there's still a big difference between CD and Aux
Back to Top View djrickp's Profile Search for other posts by djrickp
6thsense
U.S. - Virginia
Posted: Aug 02 2004 at 9:51pm | IP Logged Quote 6thsense
mine does the same.....but I just turn my mp3 player volume up and its not that noticeable
CGreenTitan
Posted: Aug 03 2004 at 10:58am | IP Logged Quote CGreenTitan
I noticed that when switching from AUX  (with the headphone output of my MP3 player connected ) to FM that the vol level is about the same. Did not feel that I had to adjust the level.
Big Tow
Utility
RF
jdwtitan
Posted: Aug 03 2004 at 11:40am | IP Logged Quote jdwtitan
I wonder if it depends on the output watts from the mp3 player.  XM isn't too bad now with the output volume way up.
SOMZ28
U.S. - New Mexico
Posted: Aug 04 2004 at 8:32pm | IP Logged Quote SOMZ28
I installed a PIE amp to bring the volume of the aux input closer to the CD player.  It is about 90% there.
2004 Titan CrewCab SE 4x4
2002 Z28 pretty modded
Back to Top View SOMZ28's Profile Search for other posts by SOMZ28
djrickp
Posted: Aug 04 2004 at 9:04pm | IP Logged Quote djrickp
Where can I get one? Thanks.
SOMZ28
U.S. - New Mexico
Posted: Aug 04 2004 at 9:09pm | IP Logged Quote SOMZ28
http://www.xmfanstore.com/showproduct.php?id=linedriver
You need to splice the the RCA cables into the aux input wires.
bigmd10
Posted: Aug 04 2004 at 9:12pm | IP Logged Quote bigmd10
I was told brand of the MP3 player has an effect on it. My friends titan sounds fine with the Apple IPOD.
04 Titan LE CC Silver
Big Tow/Utli-Track System
DVD/NAV Systems
Sliding Bed Extender
Bed Tray
Back to Top View bigmd10's Profile Search for other posts by bigmd10
