Titan Towing / Hauling
 Nissan Titan Forums : Titan Towing / Hauling
Subject Topic: MPG while Towing Post ReplyPost New Topic
Titan469
Posted: May 23 2006 at 2:52pm | IP Logged Quote Titan469
I have a 2005 Titan SE Crew Cab 2 wheel drive with tow package.  It gets 13-16 MPG normally when not towing.  I recently purchased an 18ft dual axle box trailer approx 2800 lbs un-loaded and approx 3800 lbs loaded.  I towed the trailer from Calif to Georgia a back (4800 miles)  I only averaged 5-6 MPG, even though it was mostly flat driving and was only tacking at approx 2500 RPM most of the time.
Nissan dealer checked the truck when I returned and said everything looks fine.  Any ideas?
Back to Top View Titan469's Profile Search for other posts by Titan469
miserytom
Posted: May 23 2006 at 3:21pm | IP Logged Quote miserytom
did u use the tow mode? and did u tow in 4th gear? rather than "D" ?
electricjohn
Posted: Jun 29 2006 at 6:44am | IP Logged Quote electricjohn
Trailer was not that heavy, and it sounds like you were doing 75+ mph.  I would have used 5th gear which would have drop the tach down to about 2100.
white 4x4 SE CC with big tow,pop w/capts, bed package,splash guards,and floor mats.
born on date 4/1/04
Back to Top View electricjohn's Profile Search for other posts by electricjohn
Todd TCE
Posted: Jul 08 2006 at 6:40pm | IP Logged Quote Todd TCE
And I complain about 10-11mpg at 75mph plus running 4th gear much of the time, third up hills and OD on flat ground...
I'd say you had a helluva head wind or some serious issues here. I tow about 2500lbs with the race car and its trailer. Run the crap out of the truck towing it too- curise, OD the whole thing that some feel is just so wrong. Never had, nor expect any problems.
Then again around town this truck passes everything but a gas station. With its whopping 11-12mpg. But hey; I get to the races quick.
Posted: Jul 09 2006 at 10:15am | IP Logged Quote thepuffman
4800 miles / 5 mpg = 960 gal
960 gal * $3 per gal = $2880
If you waited until you had used 25 of the 28 gal tank capacity to fill up, that would mean you stopped to gas up every 125 miles (or every 2 hours) for a total of apprx 38 tank fulls.......My apologies if all this is true, but I think after filling up the 2nd time in less than 300 miles, I would have turned around, went home and figured something else out.....lol...hopefully you just figured your mpg incorrectly....if not, DONT keep on truckin...park it!...lol
bowhunter
U.S. - Maryland
Posted: Jul 27 2006 at 9:32am | IP Logged Quote bowhunter
I have a 2005 Titan LE Crew Cab with the tow package.  I recently towed my 20 foot travel trailer from Fairbanks, Alaska to Baltimore, Maryland.  The trailer has a dry wieght of 3600 lbs and loaded it was probably around 4500 lbs.  I averaged between 8.5 and 10.5 MPG.  The majority of the time I was driving between 60 and 65 MPH and was running the A/C for the majority of the trip
Back to Top View bowhunter's Profile Search for other posts by bowhunter
logspec1
Posted: Sep 10 2006 at 8:51pm | IP Logged Quote logspec1
I have a 2005 Titan with the tow package and I tow a 29' travel trailer (7200 pds) and I get 11 miles to a gallon.  I gues I should not complain.
I do have the AirHog air filter and added true dual Borla exhausts.  I little noisy but a lot more power.
Ken
Back to Top View logspec1's Profile Search for other posts by logspec1
