| Posted: Jan 19 2005 at 11:03am | IP Logged
I have this problem also. If you go to other Titan forums you'll see this is a fairly common issue for Titans and Armadas this winter. My problem is the drivers door but I've seen posting on all the doors.
There is a looped cable that connects to the drivers handle. If this cabel freezes you can't pull the handle.If you can pull the handle - the cable may not release and will keep the latch open. This looped cable seems to be the most common problem. There are 3 cables actually - outside handle.inside handle and lock button. All these lead to the lock assembly but run horizontally except for the outside handle one which is looped and faces straight up. DUMB!
Don't know how to fix it, the lock assembly with cables is on B/O. Mine freezes HARD and SOLID but only on the drivers side. I don't know what kind of grease or lube could freeze so solid at 10-15F. Bind, stick , drag OK - but I can't budge the handle! Feels more like ice to me and since the cable is vertical it's not a stretch to think water dribbles into the cable and collects in the "loop"
I removed the small plactic plug and shot a heat gun through the hole. In 5 minutes it's working fine again. Leave it for a few hours and its stuck solid again.
