Subject Topic: Aluuminum differential cover Post ReplyPost New Topic
toms titan
Posted: Apr 05 2005 at 9:46pm | IP Logged Quote toms titan
Has anyone installed the aluminum differential cover on there 04 titan? I
am thinking about doing it, and was wondering if there are any problems I might encounter?
 I have awhite extended cab with the big tow and off road LE. I will be pulling a travel trailer with a gross weight rating of 7300 lbs.
 I will appreciate any info you may have to offer.
 Thanks Toms Titan
Tom
Back to Top View toms titan's Profile Search for other posts by toms titan
dontbuytitan04
Posted: Apr 05 2005 at 10:17pm | IP Logged Quote dontbuytitan04
I think it should be a TSB to replace it. I looked under my truck and found the paint on my rear differential peeling off from heat.
Danny
Back to Top View dontbuytitan04's Profile Search for other posts by dontbuytitan04 Visit dontbuytitan04's Homepage
toms titan
Posted: Apr 08 2005 at 10:07am | IP Logged Quote toms titan
Dan thanks for the comeback, but Nissan won't do the change under a tsb.Tjey will do only by customer payed service, and there is some doubt Nissan would honora warranty repair should the differential fail at A latter date.         & nbsp;         Thanks again for the comeback
Tom
tjjtande
U.S. - Minnesota
Posted: Apr 15 2005 at 12:59pm | IP Logged Quote tjjtande
Have a 2004 LE 4X4 with the off road and big tow package, contacted Nissan consumer affairs, told them about my concerns, said to go ahead and have the dealer install one, took about 4 weeks to get one, dealer called when it came in, installed unit at no charge to me at all. read the link below for reinstalling the rear differential oil, supposed to use Nissan's 75W/140 Synthetic Oil after any maintenance is done to the rear-end. I used Amsoil 75W-140 Sever Gear Synthetic, they have to honor any oil as long the oil meets API codes.
http://www.infinitihelp.com/Ownership/Bulletins/Nissan/2005/ NTB05-008.htm
Back to Top View tjjtande's Profile Search for other posts by tjjtande
sonnytimes
U.S. - South Carolina
Posted: Apr 18 2005 at 5:03am | IP Logged Quote sonnytimes
All I had to do was drain the oil out of the rear end. When I did this chunks of the spider gears came out and the fluid was silver in color. Took the truck back and a 05 rearend was installed. No Problems.
ned946
Posted: Apr 18 2005 at 9:13am | IP Logged Quote ned946
Why not increase capacity as well and go with this?
http://www.yourcovers.com/newproducts.htm
Nissan Titan Forum
Back to Top View ned946's Profile Search for other posts by ned946
tjjtande
U.S. - Minnesota
Posted: Apr 18 2005 at 10:03am | IP Logged Quote tjjtande
Did your truck give you any warning before at all before the failure, vibration, rattling, etc.?
sonnytimes
Posted: Apr 18 2005 at 4:03pm | IP Logged Quote sonnytimes
The traction controll system started taking over (the "SLIP" light on the dash) on the loose sand road that I have to go down to get to my house. After it was replaced, it started acting fine again.
dontbuytitan04
Posted: Apr 18 2005 at 8:34pm | IP Logged Quote dontbuytitan04
I just looked under my rear end and found gear oil seaping out of the joints around the axle and the cover.
Danny
rnss396
Posted: May 12 2005 at 7:24pm | IP Logged Quote rnss396
Just replaced diff cover with alum. one and syn. lube. about 5 miles later the clutch paks in the diff locked up and now am replacing the rear. Nissan WILL pay for the new alum cover with a little creative claim, as the steel one warps when hot and leaks, you can not get a steel cover from nissn anymore as per a service file.
Back to Top View rnss396's Profile Search for other posts by rnss396
