Subject Topic: Automatic Window Failure Post ReplyPost New Topic
MJ-SEFL
Posted: Jun 20 2005 at 7:55pm | IP Logged Quote MJ-SEFL
Has anyone experienced any problems with their driver's side or passenger side window motor?  First, I thought the problem was with my driver's side motor stalling - the dealer said the delay was normal.  Today, I put the Passenger Side window down and it just kept going, and going, and going - well you know what I mean - it got buried in the door, the motor pulley either snapped or the cable snagged and broke. Either way, this is a 2004 LE Crew Cab with less than 10,000 miles - and it shouldn't have happened!Angry  I'll let you all know how it goes with Nissan tomorrow.
Oh, and by the way, wouldn't you just have bet this would have happened in a heavy rain!
MJ from South Florida
Back to Top View MJ-SEFL's Profile Search for other posts by MJ-SEFL
Deercamper
U.S. - Virginia
Posted: Jun 21 2005 at 5:00pm | IP Logged Quote Deercamper
My drivers side window has similar problems.When I roll it down it seems like it is skipping,only when it's going down.I have a 05 titan se kc with 350 miles on it. Let me know how it turns out.
Back to Top View Deercamper's Profile Search for other posts by Deercamper
MJ-SEFL
Posted: Jun 22 2005 at 8:03am | IP Logged Quote MJ-SEFL
Well, so far, so good.  I happen to have a really decent Nissan Dealer out here in South Florida. They took the  truck in right away and immediately changed out the regulator on the Passenger Window.  They couldn't find any problem with the Driver's side window, but I have another 2 1/2 years or 27,000 miles of coverage.  I would suggest that you make a list of any problems you are having with the truck and bring it to the dealer at 1500 miles.  Get your oil changed and  have them type up a report.  Then, if they can't find the problem, you'll at least have a record and they'll be on the spot to help you.
Good luck with your window.  And, by the way, don't forget the "magic" features of the key fob,  including its ability to lower both front windows if pressed "open" for more than 5 seconds.
cintititan
Posted: Jun 24 2005 at 7:18am | IP Logged Quote cintititan
My windows have always seemed jerky when lowering them.  I'm taking in in on Monday because there's been a few times now where it wouldn't go up until I hit the button 5 or 10+ times....
Back to Top View cintititan's Profile Search for other posts by cintititan
