Subject Topic: HEADLGHTS Post ReplyPost New Topic
dboysb
Posted: Mar 08 2007 at 8:43pm | IP Logged Quote dboysb
DOES ANYBODY KNOW HOW 2 ADJUST OR ALIGN THE FRONT HEADLIGHTS? MY FRONT RIGHTSIDE HEADLIGHT SEEMS 2 B HIGHER THAN THE LEFTSIDE.
SoCal TITAN
2005 Kingcab SE
TRUXX 3" Lift Level kit
Flowmaster 40 series
AIRHOG air filter
35"x12.50x 18 stock
Cooper Discover STT tires
Silverstar Ultra Vision High/Low Beams
Back to Top View dboysb's Profile Search for other posts by dboysb
bigbear05
Posted: Mar 09 2007 at 1:13pm | IP Logged Quote bigbear05
There is a hex screw in the center top portion of the housing of the headlight under the hood. Adjust accordingly. I think there is a section in the manual that tells you what levels your lights should be at from certain distances. Beings you have the 3" mini-lift, you may want to adjust a little more than you would if you were riding at stock height.
