CactusJackSlade Groupie
Posted: Oct 01 2004 at 12:25am | IP Logged
I know there was another thread out there somewhere about this, but I did a search and could not find it... ANYWAY....
Just recently when I flick up on the drivers side window button it surges then does nothing, even if I hold the button. Each time I have to let go and wait several seconds, then it will work. If I try immediatly to raise it after it is stuck it will not budge, only after waiting several seconds... is this some sort of safety feature? If so I hope to heck I never plunge into a river!
I will definitely have the dealer look at it.
Anyone else have this trouble?
CJS
__________________ CJS
http://www.racemtbikes.com
earlofcrankcase Senior Member
Online Status: Offline Posts: 230
Posted: Oct 01 2004 at 1:12am | IP Logged
It's happened to me about the same way. You hit it, doesn't go right. Fumbel with the swith, 2 sec. later everything is fine.
Todd TCE Senior Member
Posted: Oct 01 2004 at 9:13am | IP Logged
Me three. Finally!
Somewhere this was mentioned before. I hear the motor or track parts rattle when trying to get it to go up. Only after some monkeying around does it go up.
Mine reared its head after some bumpy driving thus likely loosening the hardware.
Posted: Oct 01 2004 at 5:21pm | IP Logged
I dont know if this has anything to do with your problem, but I do know the windows have a safety feature that will will stop the window from rolling up if it encounters a certain level of resistance. It is meant to protect children, but I suppose the sensor could be broken or set too sensitive. I know when I first installed my "in-channel" window vents, the passenger window would sometimes go up then come back down a few inches.....It still does it every now and again, but usually will work right on the 2nd try.
....update....my window has acted up in months now
Kevante Senior Member
Posted: Oct 01 2004 at 7:22pm | IP Logged
I hate my windows had everything replaced. will have everything replaced again.
6thsense Senior Member
Posted: Oct 03 2004 at 10:27pm | IP Logged
just happened to me too.....I guess they can fix my window when they replace my brakes....
Patrick Newbie
Posted: Oct 04 2004 at 7:42am | IP Logged
My window actually fell out of the track. Had it fixed. Then it happened again and is currently in the shop. Dealer this time is telling me they are going to replace complete track and window in hopes to solve problem.
Tiger6513 Newbie
Posted: Nov 02 2004 at 11:17am | IP Logged
I just recently had this problem after I went through a car wash. I believe that was simply a coincedence with the car wash but that was the first time I noticed it. The window rolled down and would not roll up , however I was able to get the window up when i hit the window lock button It was very strange and I have had the problem several times now. I have an apt. this friday. I will let you know if they find anything. I wonder if there is a leak somewhere that is causing a short in out trucks electrical. ???? I'm Stumped
alaskanspawn Newbie
Posted: Nov 03 2004 at 4:16pm | IP Logged
Yup, another post explaining the whole thing here....
http://www.nissantitan.info/forum_posts.asp?TID=836&PN=1
hope that helps!
__________________ 2004 Titan 5.6SE
Born on 11/03
Hendo Groupie
Online Status: Offline Posts: 44
Posted: Nov 18 2004 at 8:20pm | IP Logged
Yep! My driver's side window does the same thing at least 4 or 5 times a week....while it's down, trying to raise it and it does nothing
