Subject Topic: Front passenger seat? Post ReplyPost New Topic
6thsense
U.S. - Virginia
Posted: Oct 06 2004 at 9:02pm | IP Logged Quote 6thsense
Does anyone notice a creeking noise from it?  And does the seatback feel kinda wobbly when you move it side to side with your hands?
I sprayed wd40 inside the pivot points of the seat and the creeks are no more...
Posted: Oct 07 2004 at 12:08pm | IP Logged Quote thepuffman
I havent noticed that with my captains chairs, but I have noticed that sometimes during moderate/heavy braking my seat will move forward just a bit. Its like the motor has a 1/4" of play in it....is prolly due to my weight, but is hard to get used to...lol...For a split second, it gives me that "Oh Sh_t" feeling like youre not gonna stop and makes me want to brake even harder.
Posted: Oct 07 2004 at 8:22pm | IP Logged Quote EvilPeppard
I notice a very slight "ticking" sound coming from the passenger front seat when no one is sitting in it.  I found it was coming from the seatbelt buckle rubbing against the leather.  I always have to straighten out the buckle after someone sits over there, otherwise it is more pronounced.
critter
Posted: Oct 07 2004 at 9:18pm | IP Logged Quote critter
6th sense, yes mine does the same thing.  when i turn the corner, it creaks if no one is sitting in it.  it's the seat back.  i'll address it if it gets worse with the service department.
Red Brawn Titan LE 4X4 KC w/ Big Tow and Offroad Packages. Also has Valentine One, Truxedo lo profile, bug shield, and bed rails.
Back to Top View critter's Profile Search for other posts by critter
IQ9*
Posted: Oct 08 2004 at 9:19am | IP Logged Quote IQ9*
I ahd the riser motor replaced and all it did was quite the cruching noise. Nissan better get to work on this one becasue paaengers get the feelling of"cheap seats" when they hear it....I didn't buy a Yugo
alaskanspawn
Posted: Oct 08 2004 at 1:35pm | IP Logged Quote alaskanspawn
Had the same issue with my passenger seat.  The service tech took the whole thing apart and out of the truck but could not fix the squeaking.  Nissan ordered a new seat but I haven't had it installed yet.  This problem gets progressively worse so get it fixed if you start hearing it.
import2nr
Posted: Oct 17 2004 at 8:23pm | IP Logged Quote import2nr
ive had the same problem with my passenger chair squeaking. this happens when anybody sits in it. The dealer told me that they ordered a SEAT FRAME for me . i haven't gotten this installed yet but ill keep ya ll updated
"I can't even remember what i wanted to forget."
Back to Top View import2nr's Profile Search for other posts by import2nr
sonnytimes
U.S. - South Carolina
Posted: Oct 24 2004 at 8:48am | IP Logged Quote sonnytimes
My passenger seat is driving me crazy. I live .4 miles down a dirt road. it squeeks every time i go down the road. It is coming from the hing joint on the door side of the passenger seat. Service is to look at it when I take it in for the safety recall on the rear seat belts.
alaskanspawn
Posted: Oct 29 2004 at 3:01pm | IP Logged Quote alaskanspawn
Just to correct my previous post, it was just the FRAME of the seat my dealer ordered too.  In fact it was quite the communication break down and more than a little annoying.  I took the truck in to the shop in the morning expecting only about a 40min wait to replace the SEAT they (2 people) told me they ordered.  After about an hour and a half into it they tell me that it was the seat FRAME they ordered and that it is a major job taking at least 2 hours to transfer all the padding etc...  Then to add insult to injury, after they finished the work I noticed that the arm rest for the passenger seat was loose.  I asked the tech to tighten it and while doing so he stripped the bolt...grrrrr!  All told it took them the rest of the day to re-thread the bolt hole and they had to rent me a car in the meantime.  So just a heads up, don't let them tell you it'll be a 40min. job when they fix this one.
jdwtitan
Posted: Nov 11 2004 at 12:13pm | IP Logged Quote jdwtitan
I have the same ticking coming from the passenger seat... it seems to be coming from the headrest... the posts are too loose in the cylinders causing them to tap the inside over every bump or road vibration...
my service department is giving me problems fixing any noise problems... I've had it in 2 times for the same rattle noises and they won't fix them.
Jason
04 Titan LE CC Galaxy Black
San Diego, California
Back to Top View jdwtitan's Profile Search for other posts by jdwtitan
