Subject Topic: Plastic on steering wheel scratches Post ReplyPost New Topic
RoadRashTX
Posted: Oct 28 2004 at 10:44am | IP Logged Quote RoadRashTX
Has anyone else had this problem?
The plastic on the steering wheel where the radio and cruise buttons are located seems to scratch easily.  I use the radio buttons alot and the paint above the volume switch is already coming off just from normal wear.
Get a Free Flatscreen - http://www.getfreetvs.info
Get a Free Desktop PC - http://www.getfreepcs.com
Back to Top View RoadRashTX's Profile Search for other posts by RoadRashTX Visit RoadRashTX's Homepage
jdwtitan
Posted: Oct 28 2004 at 12:13pm | IP Logged Quote jdwtitan
Yup, had this problem too.  Dealer replaced the steering wheel caps.
Jason
04 Titan LE CC Galaxy Black
San Diego, California
Back to Top View jdwtitan's Profile Search for other posts by jdwtitan
RoadRashTX
Posted: Oct 28 2004 at 12:32pm | IP Logged Quote RoadRashTX
I read on some other sites that after they got them replaced that they did not have this problem again.  Maybe they made some changes to the plastic.  Have you noticed this?
jdwtitan
Posted: Oct 28 2004 at 2:16pm | IP Logged Quote jdwtitan
Yes the plastic looks a little different.   hopefully improved.
Jason
alaskanspawn
Posted: Nov 01 2004 at 2:56pm | IP Logged Quote alaskanspawn
Sweet, was wondering if this was covered under warranty.
2004 Titan 5.6SE
Born on 11/03
redtitan
U.S. - South Carolina
Posted: Nov 02 2004 at 5:38am | IP Logged Quote redtitan
I posted similar problem on 10/27.  My dealer says he will replace the plastic pieces for 36,000 miles as often as I want, but he knew of no change in materials.  Apparently the 350Z has had similar plastic problems on the doors and they now have replacement parts with different type of plastic, so there is hope.
Back to Top View redtitan's Profile Search for other posts by redtitan
critter
Posted: Nov 02 2004 at 4:50pm | IP Logged Quote critter
my brother had this on his titan, and had the piece replaced, but now he says the steering wheel is not straight.  he thinks they took the wheel off to replace the piece and then put it back on slightly turned.
Red Brawn Titan LE 4X4 KC w/ Big Tow and Offroad Packages. Also has Valentine One, Truxedo lo profile, bug shield, and bed rails.
Back to Top View critter's Profile Search for other posts by critter
